BeoSystem 4 HDMI, output no have video
I am a new owner of my first acquired B & O sound system, BS5, BM5 with CD Ripper, I tried install the Beosystem 4 with a Projector, but in HDMI out i can see nothing, my projector not detect video from Beosystem 4, the connector HDMI is OK,
This is my connection.
HDMI 1 IN -------> PC
HDMI Out   ------>  Projector
Ethernet    -------> Router (I have Beolink Converter...)
AC Power
I need something?
Note: My Pc detect video output, i can duplicated and extend screen but in Projector i can see, tried with tv but i can see nothing, Help me Please.
Hi, I reset the BeoSystem 4 when i connected the Projector, my projector detected the BeoSystem 4 and  i can saw of Logo of bang & olufse, but next to 2 minutes the screen is black and my poyector lost the video. I don't can configurate my Beosystem 4 our i can configurate with Beolink Converter?
Help me :(
Help me :(
One thing to check is that your screen resolution from your computer to the BS4 matches the output to the projector. I will GUESS the input is 1080p or greater from a computer. If your projector does not match I am sure someone on this site will understand how the BS4 can match them up. Good luck.
Help me :(
Unplug HDMI, wait a few seconds, plug it back in. Wait a few seconds and picture will be there...
Same issue here. That is my workaround (since using wireless HD transmission).
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I seem to recall reading somewhere that after you set the BS4 to work with a projector that you need to unplug the power to the BS4 and then reconnect the power.
thank you very much to all and I managed to solve my problem, it turns out that I did not have the control application so the BeoSystem was placed in sleep mode, I have video :)
Schallertech wrote:
... I did not have the control application so the BeoSystem was placed in sleep mode...
What does that mean? Please specify with details. Thanks!
Ralf
