Beosystem 3 users,I need help
Thanks beojeff!
To sum up "how to on BS3"
You'll need an IR Receiver without Auto Contrast if you are connecting the BS3 to a NON B&O panel.
Connect the IR Receiver to the system 3 using a 3mm headphone jack plug. Not the RS232
You turn on the system and go from there.
I'd also suggest to disable auto contrast in the Service Menu.
For multi room audio distribution, EVERY source connected to the BS3 has to be also its analogue connections for distributing sound thru Master Link.
OldJack wrote:
Thanks beojeff!
You're very welcome. BeoWorld should be a friendly, welcoming forum and you should never be discouraged from asking for help!
Thanks Oakley
Just ordered Lintronic TT455-RT-238 with ir eye and accesories.Michael was very helpful.
Should have it here next week.
Have a nice weekend everybody!
Lintronic is a great piece.
Takes a little getting used to but when set up and working it's a really nice piece.
OldJack wrote:
StUrrock,I am not going to bother You,and any others similar to You.
Is it so hard to answer simple question: What ir receiver I need to keep my Beosystem 3 running?
Beogram 6500,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beovision 3,Beocom2,Serene
Phone any decent dealer and you'll get an answer in 30 seconds.
After making a little bit of an effort, this is a forum not a customer service centre after all 😁
update
Received Lintronic, with  Link Eye P#8087030. Bsys3 menu accessed with Beo4 navi.All in order.Setup done straight forward.
Now working on cablings rearrangements. Next to do within day or two: awaiting amigo to help me with Lintronic setup.
Thank You , Beoworlders , for yours patience and guidance (including not a customer service center after all).
Frane
Oakley wrote:
I'd attach the pin out image but I'm unable to. If you need/want it, I can email it to you.
I am struggling to find a wiring diagram for a Beosystem 3 (with non B&O TV) and the IR receiver. Could I ask you to email it to me? I know this is a long shot as this thread is quite old now.
I will send a private message with my email address when you confirm you still have the diagram can email me.
Many thanks
Stoobie
Exeter,
Devon,
UK
