kimchr wrote:
Yes, you are right. I have BL5's as my main speakers and they play the center channel excellent in speaker mode 2. But that is not surround! Even if I select the speaker mode 4 it's still just stereo played through four speakers.
What I need is my two BL5s playing front and phantom center and my two BL8000 playing the surround channels.
I have a BL7.4 used as a center channel in TV mode, but it is under the TV on the wrong wall. My cinema setup / listening setup is rotated 90 degrees for optimal BL5 placement.
Ah! Your original post didn't mention any speakers - just that you had a BV7-40, I believe.
Anyway... I think that if you tell your current BS3 that your BeoLab5's are Centre Left and Centre Right (or maybe Left Centre and Right Centre... it's been a while since I've used a BS3) and your 8k's as Left Surround / Right Surround, then the BL5's will be used to play the L/C/R with a phantom centre, and the 8k's will be the surrounds in Speaker Mode 5.
kimchr wrote:
As the software is, I have to add a second center channel for cinema mode. For testing it's two BL6000, but of course that is no match to the BL5s. That became obvious to me, when I did some listening tests A/B repeating a scene from Fifth Element in speaker mode 2 and 3.
One word of warning here... if your copy of the Fifth Element is the same edition as the copy that we use in the Acoustics Department in Struer for testing, then you should be warned that it's an old Dolby Surround (or Dolby Stereo) mix, which means that it's not a "real" 5.1... it's a matrixed 4-2-4 which means that your surrounds should be in Mono, and that your centre is a matrixed phantom right in the mix. On the other hand, maybe you have a different edition... in which case, ignore this warning... :-)
Bottom line is I'm considering buying an external surround processor or upgrading my beosystem if possible, so any input on that is appreciated.
kimchr wrote:
My input to Bang & Olufsen is a software upgrade that makes speaker mode 4 play 4.0 and not a 2+2 when a multichannel signal is fed. Alternatively allow not to setup a center channel speaker and then have the fronts play a phantom center.
Speaker Mode 4 should really be thought of as a "Party" mode, and shouldn't be considered for any kind of "serious" listening... In theory, if your Speaker Roles are set up correctly, then you should be getting a 4.x (the .x depends on the Speaker Types in a BS3) with the setup I described above.
Let me know if this works - if not, then let's start talking about what HW/SW version you have and I can do some asking around to people who know more about these things than I. My problem is that the stuff I'm working on is usually a generation ahead of what's in the stores... so I'm not a very good reference for the existing gear - but I know people who are... :-)
Cheers
-geoff
