Would like to control my Apple TV 4K with the Beo4 remote.
Descripton of setup:
The IR blaster is connected to the AV1 Control port of the Beosystem 3 (AV receiver) and the Apple TV 4K is connected to the Beosystem 3 via a HDMI cable and is properly set to link to the AV1 connection as well via the menu settings. I cannot control the Beo4 remote with the Apple TV, the joystick on the Beo4 remote doesn't respond and I cannot turn it on or off. I have programmed the AV1 connection using the pre-existing, built-in Beosys3 PUC codes for "Apple Remote" (but I'm not sure it is compatible with the latest version of the Apple TV 4K).
Would anyone be able to suggest troubleshooting tips or suggest a resolution?
Would be nice to control audio and video with 1 universal remote instead of two :-) I'm hoping I do not have to send this to a far-away dealer as many of them no longer service software upgrades or install PUC codes to beosystem 3 units in my state. I do see an option to program 'Add' AppleTV function to to the Beo4 remote by hitting List and the Red button on the bottom right of the remote...
