Beosystem 3 & Apple TV Connection Issues
Hi all I am interested to know if any member has any first hand knowledge or recommendations with the following issue:
System setup:
Beovision4 65 / Beosystem 3 / Beolab 9000 Mk11 / Beolab 6000 / Beolab 7.1 / beo link passive amp Beosystem 3 & BV 4 connected Sky box via Hdmi lead no problem sound & video output in BV 4 65  but not to outside speakers , was suggested to connect start lead from Sky Box to scart input in same av bank as sky connection . Successful!!! Sound output to outsid via beo link passive amp.
connect Apple TV via HDMI cable sound & video via TV all working fine!! No audio via Amp to outside speakers! Suggested to connect as above but with optical audio out of Apple TV to Digital Audio to digital coaxial converter & connect to SP/ DIF in second bank  altered input on Beosystem 3 for Apple TV to Audio input SP/DIF But no Audio output from Beolink Passive Amp !!!! Switch over to Sat & sky audio on TV & Outside via Passive Amp switch back & select Apple TV input & audio & video on TV but no Audio via amp to outside speakers!!!!
tried power down & repower of Apple TV but no luck
can anyone help Please??
Thanks in Advance
As I understand you need analog sound for your outside Speakers (=link room speakers).
See this for example: /forum/dutch/geluidmenu-in-avant#post-1720531
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
You'll need a DAC for the optical out of the ATV to a R/L analog input on the BSys3.
Only 'analog sound' can be distributed to the linkroom.
I use this small box for many years without any problems for sound distribution in my masterlink system:
http://www.amazon.de/Konverter-Wandler-Digital-Toslink-Koaxial/dp/B005H5JTMI/ref=sr_1_2?ie=UTF8&qid=1442401735&sr=8-2&keywords=konverter+digital+zu+analog
BTW: With the new Apple TV 4 this is not possible anymore because ATV 4 doesn't have an audio output anymore. Very sad indeed.
Regards
Räuber
Then we will have to use a 'HDMI audio-debedder' instead.
there is always a solution ;-)
Hello MM,
I think this one would do the job:
http://www.amazon.de/Ligawo-®-HDMI-Decoder-Audiosignal/dp/B00ADJIVB8/ref=sr_1_21?ie=UTF8&qid=1442413289&sr=8-21&keywords=hdmi+analog+wandler
But I also think you will need the new remote, even if there will be a PUC update available.
Regards
Räuber
