Beosystem 2300
That's an utter bargain!!! If it's all in good nick that would probably all go for around 800 pounds - i'll bet you're hoping it isn't 'hot'?
I'm, pretty sure it's not hot because this place I go to, If you are pawning anything they check that the S/N is intact. You
also have to show ID and sign like a release form. I think it's just that they really have no idea what they have. In my case, ever since
I saw a B&O for the first time, I've always dreamed of having one. The unit is in great shape, just a few dust...We plugged it in and and everything seems to be in working order. "I'm walking on Air". Not so much that everyone thinks I got a good deal on it, but just to finally have one...
Thanks for your encouraging comment though...Much appreciated
The BL2500's are good sounding loudspeakers if placed correctly, they can really kick out the sound!
What would you consider correct placement of speakers?
Personally, i enjoyed them 'toed in'. The soundstage seemed to snap into focus. I had them either side of the computer screen.
Another good place for them (to my ears) was on a bench right up against the wall with them separated by a couple of metres...
You would be amazed at how important speaker placement can be is when it comes to what reaches your ears. The surfaces in the room, the height of the ceiling, the shape and size of the space, the list goes on!
A common placement of stereo speakers is the equilateral triangle which you can see an even distance between the listening position, and the two speakers in the diagram below. When the speakers are placed this way the sound stage is coherent where such details as the vocals appear to hover in the middle of the room in front of you where they are meant to be... i'm terrible at explaining i'm so sorry.
By the way, Thanks Dave for the detailed layout for the speakers. This might actually work out for me.....
I just picked up my Beosystem 2300 (Type 2618) with Beolab 2500 (Type 6203) set of speakers (Red Grill), It also came with a BE04 remote control.
I got everything for $499. from a Pawn shop. The condition is mint not a scratch on it. The previous owner must have really taken care of it.The Sound is quality is amazing and I was really surprised that I was able to play copied CD's on it. I didn't think that system's manufactured before 2000 was capable of that. Good surprise though. Even the remote is in excellent condition, the LCD display shows nice and clear. It's as if this system was never used...I tell you.... I'm one happy guy...Thanks for Beoworld. I have learned many things about Band & Olufsen products. Before I just used to lust after the advertisement, but never though I would have one. Next to having children, I would call this my second greatest achievement in my life......
Well done Andro!
You sound really happy with your purchase. Now you need to start adding to it.
Enjoy!
Andy T.
Yes, I am very Happy.... Thank You.  What would you suggest as far as  additions?
Does anyone know how I could build on my existing 2300..other componets/accessories (Bang & Olufsen line of products)? I know I can get the wall shelf for it, but price and aesthetics doesn't really work for me. I've got a stainless steel table that I put the system on and it looks really good..any suggestions would be greatly appreciated....Thanks
Congrats to you!
Just some thoughts:
 - get a simple cable to connect your PC or mac or ipod
- get a beoport+IR Eye to connect your pc or mac and control it via your Beo 4
- get a beogram (with RIAA) and play your record through the system
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
