Beosystem 2 parts
Hi, I am looking for a old beosystem 2 or basically the DVI out side so I can put it into my Avant DVD and replace the old screen with a Beovision 4-50, can anyone help or advise?
Will not work.
The system 2 has a vga board, which the avant doesn't have. Beside the software difference, will be the deflection and it's faults detection a problem.
You're not the only one who tried. Many tried when the plasma tv's were released.
0 0 1 19 109 DESIGNTEC 1 1 127 14.0 Normal 0 false false false EN-US JA X-NONE
OK thanks, its back to plan B then, just use the Avant as a nice stand.
It’s a shame as the sound from the Avant is fantastic. πŸ™
