beosound1 review
dasun wrote:
It would be a big help, if it was possible to adjust the bass and treble. IMO it sounds too 'boomy'
There will be a software update providing bass and treble adjustments. Just like the A6 got some week ago.
I notice the BS1 is quite sensitive to where it's is placed. Also, playing lossless music from my NAS really makes the BS1 to shine sound wise.πŸ™‚
Yes it is interesting that nobody has commented much on the BS35. Does this suggest it is a dud product with little to no sales?
I liked the BeoSound 35 quite a bit when I saw it at the dealer.  It was not the best place to really evaluate the sound, but it did seem good to me.  I would have considered it more if I could fit it in.  It would have to be around 87 cm instead of 100 cm.  The BeoSound 1 and 2 are much easier to place!
The BS35 has been reviewed and recommended in Hi-Fi Choice, jan. 2017. A very positive review with 4,5 stars for sound- and 5 for build quality and Features.
That's good to know but what about here on Beoworld, with so many enthusiasts for the brand? Has anyone actually bought one?
I believe Paolo has
I have the BS1 in my homeoffice since September - where it performs gorgeous. The room is not too big so the BS1 is sufficient. When I first listened to it @ BEO in Munich it sounded nice - but not impressive. But in my homeoffice it was completely different! It sounds great. I had the Naim Muso at it was very sensitive to where it is placed and sounded different when I changed my location. The BS1 offers an excellent sound on every place no matter where I am in my office. I would not recommend it for bigger rooms. Tests are almost completely useless for speakers when you don’t know the room. I had Martin Logans and you could imagine that they sound only perfect where the location is suited. The Naim Muso sounds good if you find a good place for it and sitting in front of it - but different if you move within the room. And btw: the app for Muso is even worse than the beomusic app for iOS 😜
I never ever would buy a speaker without having listened to it at home before! Never!
The new Bang & Olufsen app for Android is excellent and completely different. I hope the iOS app will be similar soon.
anbucco wrote:
I have the BS1 in my homeoffice since September - where it performs gorgeous. The room is not too big so the BS1 is sufficient. When I first listened to it @ BEO in Munich it sounded nice - but not impressive. But in my homeoffice it was completely different! It sounds great. I had the Naim Muso at it was very sensitive to where it is placed and sounded different when I changed my location. The BS1 offers an excellent sound on every place no matter where I am in my office. I would not recommend it for bigger rooms. Tests are almost completely useless for speakers when you don’t know the room. I had Martin Logans and you could imagine that they sound only perfect where the location is suited. The Naim Muso sounds good if you find a good place for it and sitting in front of it - but different if you move within the room. And btw: the app for Muso is even worse than the beomusic app for iOS πŸ˜œ
I had a listen to the BS1 this afternoon at my dealer...
I actually urged to my dealer because @Roger said that the update for the Moment is not expected in week 51 but somewhere in 2017 (?). Its true πŸ™
Spend some time to listen to the A6 and the BS1(I know you actually can't compare them), and I was astonished how good the BS1 is sounding knowing it comes from only a 4 inch speaker.
Its definitely my choice for a small bathroom, or to replace my BL2000 now in this room. The only thing that holds me back at present is the incapability to use it with a remote, any remote.
Therefore, the A6 is capable to use with an Essence remote, and that is worth an extra point for this speaker.
Anyway, I am baffled from the BS1 and find it a very good sounding speaker expect doing very well in a small room.
Really? on Android? Then you're very lucky, it works not as expected from my Android phone.
I've had the Beosound 1 at home last weekend and it really did a great job in case it has enough room around itself. it's really a beast when you turn the volume up, always having an easyness and vividness that is great. but, sadly, the more i came to the walls, the more the deep frequencies took control. i checked it on the sill in the kitchen, where it was supposed to have it's place and it produces too much bass there, for example i couldn't follow the dialogues of the joined TV-signal at normal level because it was overlayed by the other noises. i hope the new m5 will fit better in my small kitchen.
Yes, it is an impressive speaker but as you say, quite sensitive to where it is placed. I experienced the same thing when placed it on the kitchen sill. Too boomy. IΒ΄m told that the BS1 will get the same tone controls that A6 got the other day, so that will hopefully help to tune the BS1 to where it is placed.
