anbucco wrote:
I have the BS1 in my homeoffice since September - where it performs gorgeous. The room is not too big so the BS1 is sufficient. When I first listened to it @ BEO in Munich it sounded nice - but not impressive. But in my homeoffice it was completely different! It sounds great. I had the Naim Muso at it was very sensitive to where it is placed and sounded different when I changed my location. The BS1 offers an excellent sound on every place no matter where I am in my office. I would not recommend it for bigger rooms. Tests are almost completely useless for speakers when you donβt know the room. I had Martin Logans and you could imagine that they sound only perfect where the location is suited. The Naim Muso sounds good if you find a good place for it and sitting in front of it - but different if you move within the room. And btw: the app for Muso is even worse than the beomusic app for iOS π
I had a listen to the BS1 this afternoon at my dealer...
I actually urged to my dealer because @Roger said that the update for the Moment is not expected in week 51 but somewhere in 2017 (?). Its true π
Spend some time to listen to the A6 and the BS1(I know you actually can't compare them), and I was astonished how good the BS1 is sounding knowing it comes from only a 4 inch speaker.
Its definitely my choice for a small bathroom, or to replace my BL2000 now in this room. The only thing that holds me back at present is the incapability to use it with a remote, any remote.
Therefore, the A6 is capable to use with an Essence remote, and that is worth an extra point for this speaker.
Anyway, I am baffled from the BS1 and find it a very good sounding speaker expect doing very well in a small room.
anbucco wrote:
The new Bang & Olufsen app for Android is excellent and completely different. I hope the iOS app will be similar soon.
Really? on Android? Then you're very lucky, it works not as expected from my Android phone.
