beosound1 review
Remarkably similar to the review posted by Lee.
http://www.whathifi.com/bo/beosound-1/review
So it is ovepriced for what it offers for sound quality.
I hope Bang & Olufsen learns from this!
And what should they learn?
Improve the sound quality 😎
Make a Beosound 2 with battery for the price of the Beosound 1 and it's for me !
Having seen both the bs1/2 I would pay a little more for a bs35. I don't think the quality/finishing though good is not a patch compared with the 35.
They're probably not going to make a lot of money that way.
I heard the BS2 today in a dealer for the first time and was so impressed. I will be buying one soon for sure. Incredible sound with a lovely design in my opinion. I would definitely choose this over the BS35, which when I heard several months ago at first release was pretty poor, at least to my ears. Perhaps they have changed the sound with recent software updates I don't know, but first impressions were not good. I haven't heard one since. Think the BS2 could be a great seller for B&O and I really hope this turns out to be the case. Simon.
I have the Beosound 1 for a few weeks now. I love the design and its ease of use. I have to admit, the sound is pretty bad though :) in my case, I have the Beosound 1 in the hallway, so sound quality isn't the biggest priority. When using multiroom, you can totally hear the difference in quality compared to e.g. the Beovision 11 or my Beolab 20.
It would be a big help, if it was possible to adjust the bass and treble. IMO it sounds too 'boomy'
Reading all the different comments about BS 1/2 and BS 35, it appears it's really a matter of taste.
One is spreading the (mono) sound at about 360°, hence it's place should be the centre of the room. It's made to use all the reflexions of the room too. And it's a (more or less) nomad device.
The other is spreading a (classic) (stereo) sound at about 180°, hence it's place should be next to a wall. It's not supposed to be moved from there.
I think it's simply not possible to compare them.
If you use them for what they've been designed, AND if you like the concept (360° vs 180°, mono vs stereo, nomad vs fixed), then you made the best choice.
Otherwise, chances are that you'll be disappointed...
It's like comparing a sports car and a motorcycle. Both are used to go from point A to point B, but that's all. Any other point is a matter of taste or need. If you prefer a motorbike, and use it as it should be, then it's the best. If you prefer a sports car, and use it as it should be, then it's the best choice too.
None is better, and each one is the best.
By the way, there are not a lot of feedbacks here about the BS35...
