Beosound supporting speaker display
Can someone help which of the following Beosound system supports speaker display like in e.g. Pentas:
Beosound 4 ?
Beosound 5 ?
Beosound Moment ?
Beosound 5 should work..
The BM5 is mostly connected through masterlink and diagrams shows "PL-Data". It's from an era that powerlink data was common used.
The BeoLink active supports speaker displays. So if you access most tv or Beosound through it, you’ll get the source name and track.
