that sounds much more promissing compared to the info from my shop. they were really frustrated!
BeoSound Stage & (eclipse stand-alone speaker) Beosound Centre support For LG cx/GX
I assume kawo was referring to this video. https://youtu.be/g1ndEA1Yk1U Cheers. OlivierCould you please post the link to this video? MM There is a tv - and there is a BV.
Sure - thank you!
That looks very nice and clean - much better than with the C models.
There certainly is a simplicity to the GX - but for a TV that is going onto an older BV7-40 stand (and likely never on a wall) - im still in two minds whether to go for the CX with the really thin upper half and the bulky bottom half.
After chatting with Premium Sound in Melbourne during the week - ive also started to think whether the Eclipse Soundcenter 55" at AU $6.5k makes sense to add to the LG tv - as it should mean i can still reuse my lab 6000's which are still going strong.
Luckily the speaker (Stage or standalone Eclipse Sound Center) can be a later decision - i'll get the TV first - then the STBrackets to attach to the BV7 stand.
I gotta say that B&O really dont advertise the standalone Eclipse Sound Center existence at all .... Ive asked for a spec sheet for it so ican see dimensions and mounting options - hopefully to get some way to attach to the BV7 stand too..
Its great to have choices ...
I did not realize that was an option. If you get a spec sheet, please let us know the details.I gotta say that B&O really dont advertise the standalone Eclipse Sound Center existence at all .... Ive asked for a spec sheet for it so ican see dimensions and mounting options - hopefully to get some way to attach to the BV7 stand too.. Its great to have choices ...
Well that is a really good point. When buying the Stage, I was never offered this "SoundCenter" option. Now I have C9 65 and Stage on BV7/40 stand and it is wonderful. If I ever get an offer to upgrade to the "next-gen" SoundCenter that is mountable to the STB mount... well I would!
No spec sheet - but some progress on what it is and what the plugs are :
And what it looks like ....
Is this the Eclipse,
Or a standalone soundcenter (The long rumoured Eclipse V2)?
Does anybody know the retail price of the sound centre in Europe (Netherlands)?
If I convert AUD 6.5k, it works out just below €4k, which is less than I expected.
Any insights?
