Beosound Shape
tom555 wrote:
I have a shape in my listening room as dampers.   No drivers, control, etc.  Just dampers. Looks great.  Improves the sound.  Uses no power.πŸ™‚
Slip a BeoLit 15 in the corner, cover it in acoustic cloth, invite your friends round, tell them the Shape has got a magic processor which throws the sound directly and accurately from the wall to the very corner of the room - then sit back and drum your fingers in satisfaction as they all nod sagely.
😁  😁  Mono ***
Any news when the Beoremote One BT will work with the Shape?
I’d like to know this too. The essence remotes drop out too often.
Bumbing my questions once again. Does anyone knows when the Beoremote One BT will work with the Shape?
that's a good question!
i guess if a BeoRemote One BT works with a Core? it would work with a Shape?
I think I remember a video mentioning it does
I’ll take a look again and respond
Hi Guys, some great info on here. Felt I should add this question to a current thread as opposed to opening a new one.
re Shape can I connect my TV or Sky TV box to it?
I was ready to pull the trigger but then realised the optical connection is to connect the core to the amp so that is out. I can see a line input jack but was wondering how this would sound.
I'm not looking for surround sound or anything too clever but have always run my TV through external speakers or even a sound bar but if I install the shape on my wall I won't want to have another speaker setup for the TV
Steve
You can connect the tv (or the box) using the toslink out there to the toslink in of the BS Core of the Shape.
The mentioned β€˜line input port’ can be used for optical with a small adapter piece.
This input has auto detection - means it will turn on the speakers (the Shape), once you start the tv/box.
Great, thanks for the swift reply, was wondering how that would be an optical connection as it looked like a standard 3.5mm jack
So even something like this cable would do the job -
