Beosound Shape
Here's my Shape - had it up and running since November. I must say I REALLY like it. Sound quality is great - much better than I expected actually. Bass response is very good too, better than the slimmer Beolab models (6000, 8000, 18 etc). It certainly sounded better to my ears than a pair of Beolab 17's. Beolab 3 was closer, but I think the acoustic lens helps that a lot.
I love how genuinely different it looks aswell - no-one guesses it's a speaker system. In my mind it's the most B&O thing B&O have done in a long while.
I'm using a Squeezebox Touch via the Optical In for streaming - that way I get multi-room with the rest of my house, and the iPeng app is better than the B&O DLNA based app. I've then got a wall remote and table remote for Volume adjustment. The Optical IN has auto sensing, so the whole system comes on to the pre-set volume level as soon as I press play on the squeezebox or it's app.
Happy to answer any questions from prospective buyers.
P.s. must also say that Graham and Duncan at B&O Leeds were fantastic. Really friendly, helpful and enthusiastic - makes the whole buying and owning experience a pleasure.
Grey / Yellow is a nice combo. Thanks for the report nlanks 🙂
I also think this is a great part of the purchase satisfaction 🤒
How do you judge the sound quality when seated back to the wall?
Do you mean facing the Shape, but sat back against the rear wall? If so, bass can get s bit boomy as it reflects off the walls. Come forward a few feet and it all levels out.
Or do you mean back to the Shape? Not really listened to it they way, would always sit where the pictures been taken from.
Yes, I mean this, seated in the armchair.
Your setup looks fantastic!
I agree...and the Squeezebox Touch is still a nice player setup.
If not for my integrated Essence 2nd gen, I would still use mine!
These colours in your room are very tasteful - almost tasty ;-)
Thanks everyone.
Yes the Squeezebox eco-system has not yet been bettered in my opinion - affordable, customisable, Toushscreen products and great 3rd party apps
nlanks wrote:
...Sound quality is great - much better than I expected actually. Bass response is very good too, better than the slimmer Beolab models (6000, 8000, 18 etc). It certainly sounded better to my ears than a pair of Beolab 17's. Beolab 3 was closer, but I think the acoustic lens helps that a lot.
Hi nlanks,
How many speakers does your setup consist of?
excuse my ignorance, does this mean you dont use the core, but just the shape amp?
also, what type of remotes do you use, essence or other?
Thanks in advance,
//Goran
Any idea when support is coming for the BeoRemote One BT for the Beosound Shape?
CB wrote:
Hi Stuart and thanks for the picture
According to your experience, which form sounds best?
Is the support wall material very important?
Hello and thanks. I had previously written a lengthy reply and accidentally closed the app on my phone before sending.
We decided to add the smaller Shape so it could be represented in the showroom. Having seen a lot of posts on Instagram and Facebook smaller Shapes are very popular. The big Shape we have is the equivalent to a pair of BL20 with a BSCore in price and sound and the 9 tile Shape is more in line with a pair of BL17 and BSCore.
Our larger Shape is fitted to a plasterboard wall and we found that there is zero vibration when playing music at high volume, the only issue we have is the suspended ceiling and tiles! The small Shape is mounted on a normal B&O in-store display panel and again no issues. If you’re fitting directly to a brick wall it will take longer to install due to plugging each hole and there’s 3 per star rail piece.
To give you an idea of sound equivalent speakers vs Shapes I thought these pictures would be useful.
