They snap on / snap off. I once used a butter knife to gently pry them off at the outer edge.
Beosound Ouverture - glass door issue
No the belt was 100% i checked it carefully.
The little "bump" in the motion is probably from that my screwdriver was to big to adjust the bottom screw (very tight with space) so i just adjusted the top once, will buy a smaller screwdriver and adjust the bottom later. :)
Check this youtube clip then you see how to remove the black plates, it worked fine for me after viewing this :)
Hi Leslie;
Can you show me how to fix these doors that only open partially??
Thank you so much,
Paul
Hi Leslie;
Thank you so much,
Paul
This is usually just because of dirt and dust on the bottom gliders.. You need to clean it good.. Try that firstly
/Weebyx
I've cleaned the tracks and applied a small amount of WD40, but still not operating properly.
When closed, I wave my hand in front and they open about 2 inches. I need to gently push them open all the way. They do not close automatically either... stay open.
If everything has been cleaned, adjusted and the belt is OK, sounds like a motor or gear problem with the mechanism. Cheap to buy but will depend on your competence to fit.
Dave.
There are a small switch located with the motorpulley, that detects where the glassdoors are. This switch can get very dirty, and could confuse the processor as to if the doors are open or closed.
The big white wheel touches controls this switch. Clean this switch, with a piece og "thick" paper with alcohol on, this will work as sand-paper, but not as rough.
You need to take the back off the unit, and also the black panels behind the glass.
Have you tried to open and close with the glassdoors off ?
/Weebyx
I'll try that over the weekend.
And no, I haven't tried to operate the door mechanism with the glass doors off. I'll try that as well and update you.
Thank you!
