BeoSound Moment master link connection
I will sell my BS 5 and buy the Moment. Does anyone have experience with the NL-ML converter?
I would also like to do that but my dealer told me to wait for the multiroom software update that hoppfully soon will come.
/forum/general-discussion-and-questions/uk---bt-wireless-hub-and-phone-to-bv5-and-com-phones#post-1847151
There are some minor issues. I bought mine about two weeks ago. It is working very well beside the linkroom issues mentioned in the link.
The possibility to use the Moment in a masterlink and/or networklink will be coming around 15 May with a automatic software upgrade.
Until that day you can only connect to ONE source.
Thats correct, but if you only have ML and a Moment connect thru a NL/ML converter its work fine
