Beosound Moment & Pattern Play
Thanks Tassos, this is very helpful. I guess the workaround I could try is to always end my day with a Moment source so I can enjoy pattern play the next day ;-) (or better: follow through with B&O and see if they are kind enough to fix it for me / us).
I did in the past use the Moment with the Beolabs separate from the TV and I agree it made the experience better / snappier; that said I am mostly fine with.....
............. the integrated set up as well. The drawback of using the Moment directly with the Beolab 5's is that the sound quality when watching movies (bass!) is not as good as with the integrated set up..........
FYI for others that have the same issue a workaround that works (at least partly)
I now reset, with an automatic power switch, the Moment each night and this solves it: pattern play then works as it should.
Note that this does not solve everything as when you watch TV in between using the Moment the issue remains; less of an issue for me though).
Peter
Tassos wrote:
By the way, if you have the possibility to make the moment a stand alone system it is much better to interact with it. Volume is much easier regulated, the whole experience is much faster and accurate and the bang Olufsen app works much better as it does not let you get confused on which source is available for each device.
I have abandoned the integrated set up and indeed: much better
One open item for me is that the remote control does not work with the BS Moment (volume / next song etc).
The user guides are not so helpful, but I am sure someone on the forum can help me to solve this?
(set up: V1 and BS Moment separate)
thx in advance.
