Beosound Level - new soundbar?
It does feature internet radio, albeit not TuneIn but B&O’s own internet radio service.
A bit confused by something, and can't quite figure this out....
Is it a BT/wireless speaker designed to be charged up when low on battery, or a mains-powered speaker that has the option to be portable?
What a nice speaker(system). But no TuneIn. Why ??
Essentially both and that makes it unique! But portability, IP-rating and ease of attaching the magnet charger means that actual ease of use of the battery mode is much higher than with the BeoSound 1.
My personal opinion is the latter although it does fit your first option also.
Deleted
As always, I shall wait until I see one in the flesh to give a definitive opinion, but one of the press photos that was sent to me shows the light wood grille at such a angle that the shadow of the speaker cutout underneath can be seen.
Unfortunately his makes it look like one of those old radios wit a beige coloured grille, where the cloth has got so dirty, you can see the shape of the speakers marked out in dust and grime!
Hi guys, maybe a dumb question but is it possible to use my Beoremote one, hit the music button and choose Tunein on the Level? Or internetradio?
Can the BeoSound 2 do that or the Balance?
Thanks for any reply guys.
Sandyb wrote:
Agreed - not only does the BS2 sound good deal better than the BS1, I would take some convincing that the Level sounds as good as the BS2.
I own a BS2, BS1, Edge, Stage and Balance and can safely say the BS2 is the standout of the bunch. It's not A9 class, but it's very balanced.
I have a feeling the new Level will be more like the A6?
