BeoSound Level incorrectly reports that mic is off
Hi folks - I’m flagging an issue I experienced today and the fix. While the BeoSound Level was connected to the mains I tried to re-run room compensation from the B&O app.The app reported that the mic was turned off, so I flicked the mic switch and tried again. Once more the app reported that the mic was switched off. This time I visually checked the switch position and it was definitely on.I tried again in both positions, and regardless of position the app reported that the mic was off. Rebooting the Level from the app made no difference. A factory reset corrected the issue, and room compensation measurement ran to completion.Note: I haven’t tested whether I can RE-RUN compensation.
Hi , it happened to me 3 or 4 times but no more and everything ok since 15-20 days
