Beosound Essence volume
Thanks for quick answer. I dont remember, just followed the instructions in the update. Is it just to try that now without other problems ? :-)
Someone who knows? Is it just to press reset after update, without complications?
Because a reset is a reset. To what, to the original firmware? I dont want that back, because its horrible.
I have read the instructions, and i cant interpret it your way.
Just because there is a button I dont have to press it like a child.
Difficult?
Difficult?
Had the same problem. Updated the software and all issue solved. Easy as 123🙂 reset should do the trick
It was solved by pulling the power plug 😎
Ps. "Line-in" on Android Beomusic app (2015-05-18) still does not work. But on Ios it does. Ds.
Having same issues but no software update available
