Millemissen wrote:
@Razlaw
I assume, that you have no speakers connected directly to the BM5 - BS5 is in 'Option 0' then!?
Depending on which option your BV10 has, the 'wheely' in ir-mode will turn that on (or not).
Depending on, whether your BV10 is MLinked or not, there will come (Net)Radio or no sound from it.
Or maybe I did not understand your description of the setup correct?
Why not just use the Beo4???
You are correct, no speakers connected directly to the BM5 and BS5 is set to option 0.
BV10 is in option 6
BV10, BV7, and BM5/BS5 are all connected by Masterlink.
Yes, I could just use the Beo 4 and that is what I have been doing. The Essence remote is somewhat of just wanting a new B and O toy, with a little added ease of use.
If I am walking through the room, I can press the Essence Remote and turn music on. If I want to select a specific track I am right there at the Beosound 5.
Also, am hoping that a long press off on the Essence Remote will turn both rooms off when I have both on. I have an old link ey on the wall and do occasionally use it to turn entire system off although it serves no other purpose. It was installed in the room along with an active kit before I had a tv in the room.
My plan is to replace the link eye with an Essence Remote using the Settop Brackets adapter and gain a little functionality above the ole link eye.
Am I missing something? Do you see any problems with my plan?
Thanks!
