Beosound Edge - Reactions?
milva1 wrote:
For those of you who think that the Edge is expensive check out the latest competition in the same price range:
https://www.dali-speakers.com/loudspeakers/callisto/
Milton
Not really comparable though is it? Kind of like saying if you think the Edge is expensive you should look at the Beolab 50!
I just don't see many buyers. I want equipment that will make my home theater sound even better. I think the edge is wasted energy on B&O's part.
Disagree. I don’t have office floor or wall space that can handle an A9 or Shape, but a wall mounted Edge will be PERFECT!
B
I wait to see it in the shop before final jugment.
Not impressed at the moment by the looks and don't imagine touching it for volume (but it's a good B&O idea).
Sound must be top notch, the most important.
On the wall with a Rolex dial fret you can make your dinning room a Rolex authorised dealer lookalike.
Lots of room for creativity ...
Barry Santini wrote:
pjk561:
Barry:
Sure Barry, however PJ was saying he wants something for a home theatre, and so like him I am puzzled how I would use a pair of Edges ... unless it makes a great central channel
B
For Barry, another AR however it is a wall mounted Edge ...
Nowhere to hang it ... This is the AR App’s UI ... the wired cross-hatching appears when the App detects a surface where you can hang or place your kit ... so I chose a spare picture hook 😁
One side and its innards ...
And now from the other side ...
BeoNut since '75
And which side are you always looking on? The bright one?
BeoNut since '75
Endless possibilities...this one on a safe side 😐
Milton
Callisto 2C (€2800/pair)
Callisto 6C (€3600/pair)
DALI Sound Hub (€600).
Aren't they comparable pricewise? Anyway, I'd say all major speaker producers are moving in this direction (hi end bluetooth active speakers controlled by mobile phones) for those who are sick and tired of low quality bluetooth gadgets. I think B&O just couldn't miss this appointment stating its' presence with a highly innovative product compared to more conservative ones (like the Dali's). Not suitable for a home cinema setup though....
