Beosound Core with optical in audio from third party TV
I have connected a third party TV to my Beosound Core via the optical input. However I have a delay on the sound. There is an option in B&O app to disable the audio delay, but it changes nothing.
Does anybody running a similar setup know if the “disable audio delay” is working (and I have a defect Core) or whether the option of disable the audio delay on optical in never have been fully implemented?
I have a Samsung TV connected to my Core Optical IN, audio delay is disabled and it is working fine.
Many thanks - so point towards a defect unit.
is auto sensing working on the optical in - core turns on when signal is detected?
Yes it is working as expected. When signal is received on the Optical port, Core wakes up or switches to Optical if another source was already playing.
No, it rather points towards a setting that you obviously haven't made (yet).
Have a look here:
Reboot was not enough - full factory reset - and it works.
Many thanks for quick feedback
