Thanks for all the insights around the Core. You guys are tremendously knowledgeable!
How does the Core connect to NL? Is it via the Ethernet port (listed below as one of the available ports according to the B&O Core web page)?
I'm interested in using the Core in a multi room scenario. Consider the following: Can I start audio streaming in the bedroom on, say, an A6, and then have the Core join in the living room, distributing the same stream to all other NL and ML devices in the house (ML via NL/ML Converter, obviously)? For the ML segment, would the NL/ML Converter act as the Audio Master in this case? Note that I am less interested in connecting speakers directly to the Core via the PowerLink sockets.
Conversely, if I start audio streaming on the Core, I would assume the aforementioned A6 (or A9 or M5) can join wirelessly. Is this correct?
-bab
Core Connections
1 x USB-C (for power via external power supply)
1 x Power Link socket (RJ45) with two channels
1 x Line-in (analogue & digital combo) with sensing
1 x Ethernet 10/100 Mbit/s
1 x Toslink digital sound out
1 x USB (for connection to the BeoSound Shape)
