Beosound Core or Sonos connect amp?
Let me throw the Bluesound Node 2 in the mix as well which I have in our bedroom connected to Ruark Mr1 MK2 speakers. Monthly recurring updates, has Deezer Hifi, Tidal Hifi and many others (including ability to stream MQA).
Have the Bluesound as a backup for my Moment (to connect to my Almando switch when necessary)
I still have my good old Squeezebox Touch controlled by the iPeng app (on iPad)
(I’ve had the Touch long before the concept of the Essence/Core was born)
It is nowadays connected to the line-in of my Essence box....and (the sound of it) can therefore be distributed over my NL.
I don’t use it very often anymore, but won’t let it go (access to my NAS collection, Spotify and netradio).
If you don’t need the NL-functionallity of the Core, don’t want the B&O X app as a controller and you aim at a standalone setup, there are lots of other possibilities on the market.....from resonably to insanely high priced!
With the Core you get AirPlay, ChromecastAudio and bluetooth - something, that the Sonos can’t bring on its own.
The concept of the Core is versatility - it can be used in different situations/user cases, with different preferences (and in a NL-setup, if you want to).
Not everyone need all these functionalities - if you have a specific preference, there are lots of alternatives out there. Some people are happy with a ChromeCast Audio dongle (with the right settings).
Thanks for your help.
In theory, I like what the Core offers a lot, but I am worried that it will be plagued by the kind of software problems that have been present in a lot of B and O products recently (moment, essence...) whereas sonos is far less prone to connectivity/software related issues.
I have had no issues with my Core
Martin wrote:
If You buy an Auralic Mini (price almost equal to the Core and Sonos) you will get a very good streamer with very good sound quality.
/Martin
I can vouch for this. My friend has one, it's a superb product and has been trouble free. If/when my Playmaker goes belly up, this is what I'll replace it with.
Is there away to use this with 1656 amp.
And how?
Jeff
Beovirus victim, it's gotten to be too much to list!
Does the Auralic Mini have volume control?
Jan
Yes, Aries Mini have volume control but you can disable it if you wanr
And how?
This should be possible with the core as this is how I use my BS Essence connected with and RJ45 to powerlink (from Soundheavenly) into the amp and this then drives a pair of Beovox 1 in the bathroom. Works very well
And how?
Did you mean use the Auralic???
