Beosound Core “integrated setup” option?
Hi all!
I’m discovering my new Beosound core..
I’m couldn’t figure out what does this “integrated setup” feature do…
It’s hidden in the Product Settings > Configure > Settings > BeoLink > Link to other products
Any hint appreciated!
It integrates with a beovision when you have your speakers connected to your tv
When you choose this you only see the sources of the core and the beovision in the app.
One picure…. 😁 says more then 100 words look at this setup in my little girls room
Or the ML sources if a BLC is integrated
Thank you! 🙏
Carolina, just to make sure I understand, in the first picture the BS Core is integrated to the BeoPlay V1, and in the second picture the BLC NL/ML is integrated to a BS Core, correct?
If so, for the second pic, in which product do you tick the INTEGRATED check box? The BLC or the Core?
I assume that the speakers (i.e. the Shape) are attached to the Core.
Correct, in my case the Core is part of a Shape.
the Core
Note: in the BLC the "Connect to" both (primary and secondary) are set to BS9000 BLC (thus the Beolink Converter NL/ML)
Edit: the BLC is set as ASlave
Fascinating. Thank you, Carolpa. I still have a lot to learn about the BLC NL/ML.
After that… the BLGW [:\'(]
I habe a similar question. Perhaps someone can help.
I warnt my BeoVision to be activated automaticly if i AirPlay to my Core. Is this possible with integrated Setup? When I choose integrated setup Max beovision won‘t activate the picture when I select DTV. What am I doing wrong?
My setup is the following
BeoSound Core (with turbtable) and BeoVision 7 with BLC NL/ML Converter. The BLC NL/ML Converter is set up as A. Master.
thanks for your help
p.s. Anyone else has Problems with TuneIn since  yesterday?
Leider nicht möglich mit "integrated setup". Das ist wohl möglich mit eine BV11, V1, Horizon, Avant.
Mit eine BLGW oder BLI wäre das wahrseinlich programierbar.
Sorry, not possible. With a BV11, V1, Horizon, Avant it would be available
Presumably with a BLGW or BLI it would be programmable.
