Beosound Core Deezer HIFI
Beobuddy wrote:
To be more complicated.
The Core in this setup is integrated with the BV7-55 via the NL/ML converter
OT: interesting setup. Do you airplay via the core to the BV7? If so, does this work if the BV7 is turned off and does it play without turning the screen on?
The setup works like a "traditional" setup, like with an Ouverture/BS3000 or any other Audiomaster with ML. In this scenario the BV7 takes the commands through infrared, but the screen stays off. Only the display at the side of the BV7 shows what's playing. Here the NL/ML converter, combined with the Core, replaces the Ouverture/BS3000 and act the same the same way.
If you select CD and the Core starts playing, but you can overrule that by start using Airplay to the Core. You can also start using Airplay to the Core from standby and the converter will trigger the BV7-55 in audiomode (no screen).
Very cool, thanks! Does the BV7 also eventually turn off once the AP2 stream stops?
If you stop casting or airplaying to the Core, then after some time, the system will go to standby, yes. The same counts when your playlist has been  played and stops.
I am sorry for taking it up again, however I needed to confirm with Bang & Olufsen Support again, after information I have received from this forum. So I asked following:
Question:
"I have just received different responds from different forums and different Bang & Olufsen Stores regarding if the build in Beosound Core actually supports Deezer Hifi or not.
Can you please confirm what is earlier stated from B&O support: ”The built-in Deezer app on the Bang & Olufsen application only supports normal Deezer”
Answer:
"Thank you for getting back to us
We can indeed confirm what we said earlier is true, the built-in Deezer app on the Bang & Olufsen application only supports normal Deezer however via the Deezer app you can stream Hifi using Airplay 2 or Chromecast to the Beosound Core"
So, please take not to this and please make comments..
I really don't understand the above B&O support statement :-(
The B&O app is only a Deezer "controller", not a a Deezer "music player", that is controlling the B&O device's integrated music service, i.e. Deezer so Hifi or not at the app level is irrelevant.
When you have a subscription to Deezer Hifi, that your B&O device is Deezer HiFi capable and that the track you are playing is available in HiFi format, then the B&O app shows the FLAC logo close to the Deezer icon in the now playing screen as mentioned by other members.
Question:
"That being said, so even if i have subscription on Deezer HIFI, log in at Beosound Core with my account, I will not be able to stream higher than normal Deezer?
 Besides then of course to use Deezer’s own app and stream As you stated before"
Answer:
"That is correct the Bang & Olufsen App's Deezer integration only supports normal Deezer playback from the app itself, HiFi is supported via Airplay and Chromecast by your Beosound Core. "
Question:
"Just a last question, why is it stated ”FLAC” in the Bang & Olufsen App when playing from Beosound Core?
As I understand from your earlier reply this is not correct?"
Answer:
"B&O app will indeed showcase that the reproduced file is FLAC as it is being reproduced from a Deezer HiFi account, but unfortunately due to the different bandwith that HiFi Deezer uses and the one that the B&O app can handle, the format will adapt to one that our App is able to stream.
We are sincerely sorry for any inconvenience that this may have caused you."
What is your thoughts about this?
Seems incredible.
The app handles FLAC over DLNA.
Millemissen: Yes, sounds incredible for me too... Wonder what is going on at B&O..
A quick look at Deezers HIFI own homepage they refer to B&O as brand that all their product will support Deezer HIFI.
Now this makes me wonder... I’ve also asked Deezer themselves a question if they have a specific product-list. No answer yet...
I think the given answer simply isn't correct!
The app doesn't need to handle the stream, but only the information which comes with the music. If you use the app to start the music, you can walk away or shut off your app and the music keeps playing. So, the music doesn'r go through the app. As simple as that.
Bandwidth isn't an issue. Despite the 100Mb ethernetsocket, it has enough margin for Deezer HiFi. Do not forget that Deezer HiFi is the same as uncompressed music, like the stream that comes from a normal CD.
