BeoSound Core Compatibility
Hi All, I have a number of B&O products however I thinking of purchasing a BeoSound Core for my main 3rd party system and i'm wondering if I can use the BeoSound Core and connect it to my 3rd party DAC via the optical out on the Core. I could then essentially control this 3rd part system with the BO App.
Would appreciate any advise.
Hi dgarratt and welcome to Beoworld
Theoretically you could, but you would have to control the volume outside the app, eg in the 3rd party system.
As far as I am aware the volume of the SPDIF-out (of the Core) is fixed.
The BS Core however has its own DAC built-in - why not use the analog PL-output directly?
P.S. Which ‘3rd party system’ do you intent to connect it to?
Although I don’t use the optical out of my Core, it can be volume regulated.
This is can be set with the app under configuration-sound settings-optical out.
The sampling rate can also be set.
Paul
Thanks for the info, liberal.
Would it be possible for you to post a screenshot (one or more) of the configuration settings options.
Not much to gain from the official B&O guide in this matter.
@dgarrett
Seems that you might give it a try then ;-)
Hi Guys, thanks for the replies..sounds like this could/should work.
I'm also glad to read volume control should also be achievable!
Will make the purchase and give it a go. Will report back with my findings once i've had a chance to test.
D
dgarratt
I would love to know how you get on, and to see any screenshots of the UI too.
I'm using a RoonServer, playing through a Chord DAC to play my Hi-Rez collection - which is distributed via my BS Moment via it's line in. I don't really use the Moment's UI anymore and am thinking the Core could be a much more discrete replacement.
I love the design of the Moment, and have it proudly on display, but like so many things now, relay on the smartphone.
Many thanks in advance & good luck!
Here are some screen shots form the configuration settings on the app
Line In Settings
Optical Settings
