If you just push on the newer version, join will not run, but it will receive commands. This must be done with a BR1 or a BEO4. This is not part of the setup. According to the Essence remote's specifications, Mode 0 is Bluetooth and Mode 4 is Beo4 IR for a BeoPlay device.
Beosound core and IR eye
Thank information!
Can you send a link to the 3rd party Ir eye you are using?
Sure, it is a cable like this:
https://uk.bosscom.com/product.asp?id=1224&m1=1334&m2=1342&m3=&m4=
However, I bought it from a Danish retailer website (https://www.av-cables.dk/ir-eye-rj45-kabel-3536/ir-eye-rj45-kabel-sort-2-m.html)
I believe the Bosscom product is only for SENDING IR commands, not receiving.
It makes sense if that is the case. Thank's for your input.
