Can anybody explain how you remove the Century speaker covers to change them for a different colour? any links showing diagrams would be very helpful.
Thanks,
John.
Thanks,
John.
If I do remember it right you just remove the 4 screws (2 in each cover) in ther corners on the back an then you can slide the cover frames off. Very easy
Yep Madsky is correct there. I did not know that and I remember spending hours trying to yank those dam speaker frets off. My poor lil Century :) She was excited though when she had new black little numbers on!
Thanks to you both for your help here. I will try this when I get in to work tomorrow and let you know how I get on.
John.
if i recall correctly even after you take off the screws you have to slightly pry (lift out and then to the side) them off on the edges (especially the corners). otherwise you can break the small tabs.
