Beosound Balance
I'm sorry Suneet!
The NL-speakers are the speakers that work on the "Networklink" Multiroom. So the M3/M5, A9, Core, Essence etc. All modern speakers. Except the Balance, which has launched on a new platform.
The BeoLiving Intelligence (BLI) is a home automator which integrates control of lights/shades/cameras with the B&O AV products. If you use BLI, you can use a separate app to control your music, lights, cameras etc.
“Worlds best smart-speaker”
Link (in Swedish) https://www.ljudochbild.se/test/hogtalare/bang-olufsen-beosound-balance/?_gl=1*3oeul*_ga*YW1wLW9MbmtxMExxWF9zcGtoMXR6eERMemVNa3Q4QlhaRWUyVmdqS21Qb0ZNaEdQb3VqQ1RLOGZ1Q0RTTzZjLUhieVE.#lesvidere
There is a video as well linked to the article
Hello to all,
I need advice. I read link and I am little confused. Can you tell me please what is difference between  and
The version with GVA has a microphone built in to give voice commands to Google (just like you would do on a Google Home-speaker). Furthermore you'll have four short cuts on the top plate you can configure to send some often-used commands to the Google Assistant (like play playlist X, play radio Y or more general Google questions like if there is any traffic on your commute.
The non-GVA version doesn't have a microphone, but you still can use Chromecast and the Google Home app on your device to control the BS Balance. Just no voice assistant built in.
In future, the GVA-version will software update to also include the Amazon Alexa voice assistant.
suneetjulka wrote:
Hi All,
My Balance with GVA doesn't automatically switch to the line-in when I switch source, I have to manually unplug and reconnect the optical audio cable that goes into my TV each time I want to use the Balance as a TV speaker...
Hi Suneet,
Do you have any news on this issue? Can you fix the volume for the line in? I’m thinking about getting a Balance too but want to connect it to an older Masterlink product via line-in.
Hi 1990,
If you use a Powerlink output from the older product to the Balance, you can use the volume control of the older system to adjust the speaker level.
A cable like this is all you need from a Powerlink socket to the Balance:
Thanks Steve! Do you have any info on the auto sense?
Hi 1990,
No sorry, I am not able to get to a B&O store to test this at the moment due to lockdown in the UK.  B&O haven't responded to any of my questions about this.
Are any Balance owners able to comment on whether the speaker can auto sense for a signal on the line input please?
Kind regards, Steve.
I’ve asked my dealer too, let’s see. BTW, could you add a Balance as a speaker to an NL/ML converter? Is an RJ45<>3,5mm possible @Steve?
Hi 1990,
I haven't tried using the speaker directly with an NL/ML Converter, so I wouldn't recommend this.
