I think I have the same problem. From system log its show that it can connect to B&O time server, and the time does sync on power up, so I think the network connection is ok. Is the service tool and SW downloadable from internet? Or my only choice is take the BLC down to the service centre?
Beosound 9000 with Beolink NL/ML or Essence Mk2?
Got impatient double click and double posted.
After send the BLC to the service centre for 2 weeks, it was fixed. The mainboard was replace. I was shock when I saw the bill. But luckily although I bought it used, the 3 year warranty is still valid, so I do not have to pay anything.
Can anyone tell me what is the meaning of "A Master" and "V Master"? It seem that only for "V Master" the BS9000 icon is selectable for BeoMusic. I just intend to connect the BLC to BS9000 and distribute the CD source to other NL devices. No speaker is connected to the BS9000.
Wee
At start I did find these remarks also confusing.
Thumb of rule is:
if you choose V.Master for the BLC, NL thinks in the ML system it, the BLC is the Video master. Therefor you have the audio sources available for the NL system. This is the reason you have the BS9000 icon.
if you choose A.Master for the BLC, NL system thinks in the ML system the BLC is the Audio master; you have the Video sources of ML available as sources for the NL (the BS900 icon isn't shown).
in your setup I would choose V.Master (or A.Slave)
I have finally installed the BS9000 and got the multi room working. I would like to thank Lifetstyle AV, STB Brackets and Sounds Heavenly for making this possible.
The control from BeoMusic app was limited. I am unable to select which CD to play. I am wondering if this is the limitation or I did not configuring the BLC correctly. I also tried the BeoRemote app but I can only start the CD player. Is Beo4 remote control the only way to change CD?
From what I read in BS9000 manual, on the Beo4 remote, up down forward and reverse the track on the same CD. Left right move the carriage to the next CD.
I tried using the BeoRemote app which have the arrow keys but it does not work.
While my setup is ML based and with my Moment as the only NL product, I've set the BLC ML Role to Source Center which then makes the communication and control to my BS9000 totally transparent . So when pressing CD on my Beo4 I can without any problem choose which CD I want to listen to by pressing 1-6 on the remote.
Only on the App and on the Essence's control wheel. Seems that <> were not implemented.Left right move the carriage to the next CD
