Currently, all the B&O stuff that I owned are NL based, Moment, Essence MK2 and A6. The multiroom function works with all 3.
I am thinking of adding the iconic Beosound 9000 into the mix. It would be used as a pure stand alone CD player, distributing to the other 3, what would be the best choice, a Beolink NL/ML convertor or Essence Mk2? The Beosound will be place in a different location from the other 3, hence using the line-in of any one of them is out.
There is very little information that I can find on the Beolink NL/ML convertor. I am hoping anyone one can help me with the following question:
1) Does the Beolink NL/ML convertor comes with Wifi or only wired ethernet connection?
2) Does it support multiroom?
3) Can I control the Beosound 9000 via apps like BeoMusic thru Beolink NL/ML convertor . Or is there some other apps that I can use? What kind of control is there, like selecting CD, skipping track? I do not intent to get the B&O remote control.
Any thoughts on the pros and cons of either the Beolink NL/ML convertor or Essence Mk2?
Thank you very much.
YW
