Beosound 9000 with Beolink NL/ML or Essence Mk2?
Currently, all the B&O stuff that I owned are NL based, Moment, Essence MK2 and A6. The multiroom function works with all 3.
I am thinking of adding the iconic Beosound 9000 into the mix. It would be used as a pure stand alone CD player, distributing to the other 3, what would be the best choice, a Beolink NL/ML convertor or Essence Mk2? The Beosound will be place in a different location from the other 3, hence using the line-in of any one of them is out.
There is very little information that I can find on the Beolink NL/ML convertor. I am hoping anyone one can help me with the following question:
1) Does the Beolink NL/ML convertor comes with Wifi or only wired ethernet connection?
2) Does it support multiroom?
3) Can I control the Beosound 9000 via apps like BeoMusic thru Beolink NL/ML convertor . Or is there some other apps that I can use? What kind of control is there, like selecting CD, skipping track? I do not intent to get the B&O remote control.
Any thoughts on the pros and cons of either the Beolink NL/ML convertor or Essence Mk2?
Thank you very much.
YW
A: It uses wired connection
A: Yes, it does support Multiroom
A: I think you can use the BeoMusic to control your Beosound 9000.
Hi Zerocool and MM,
Thanks for the answers, I think I have decided which direction to go.
YW
I have gotten a pre-own BLC NL/ML. I am a problem updating the the SW. I have seen previous posting of about this issue.
I am able to connect to BLC via web interface as well as Beomusic and Beosetup.
When I tried “Check available version” or “Update”, the “Update Status” remains as “Unknown”. Current SW version is 1.4.0.18322. The automatic update is enabled. System log shows that it is connected to B&O Server on initial power up.
I have connected my iPhone to line-in of BLC, it is able to distribute to the NL product that it is connected to primary.
Has anyone experience this before, and knows the solution for this problem?
Thank you.
YW
I would factory reset the NL/ML converter.
press the button in the hole aside the green led. After the 5th red sign release the pin you use to push the button. Within 3 sec repress the button. Then update to the newest version.
Note if you didn't make a backup to restore the setup after factory reset, you have to setup the NL/ML converter again.
Hi Carolpa,
Have tried that. The setting when back to default, however, still unable to update SW.
YW
dreammer wrote:
Hi Carolpa,
YW
did you unplug the LAN and ML also during the factory reset?
I have forgotten whether the LAN was attached when I did the factory reset, I will try again without the LAN. There are no ML cable attached to BLC at the moment, still waiting for cable to arrive from Sounds Heavenly.
2 months ago I had an convertor that wouldn't update. I had to do it manually with the Service Tool
If you're unlucky, yours could have the same problem
