I have a BeoSound 9000 and it's about 18 months old. In the last few months, I've experienced a few rare random incidences where when I play a CD, it would spin out of control, the player makes this screechy noise then the spinning would stop and then CD would fall out of the clamp. This only happens in disc 1 and it has happened to both burned and original CDs. The player is mounted horizontally. I’ve kept it in mint condition, it’s clean, no dust, etc. I’ve called the local B&O service guy as the player is still under warranty and he hasn’t encountered this problem before. He said it might be the laser not recognizing burn CDs and would replace the laser if that was the cause but this happened to both burn and original CDs. Other than that, he would not know how to fix it unless he can recreate the problem.
Have any of you encountered this problem or know what is causing this? Thanks for your help! J
