Beosound 9000 problem with cd's spinning
Hi, i have a beosound 9000. For some reason the cd's have stopped playing. Will not spin, but will somtimes. Stays on Pause.
Do you think that it has something to do with the laser. I have downloaded the Service Manual to do the test modes but looks a bit technical.
Is this easy to do?, or shall i take to B&O?.
I had since now 2 beosound 9000(MkI and III). It happened to me on each one and to make them work again I cleaned the laser lens....
hope it helps...
const
Thanks for that.
How do i clean the lens and is there a special way that this needs to be cleaned.
I use a dry cloth, wipe slowly and carefully removing as much as you can I suppouse, no special method as far as I know.
Keeping the 9000 free of dust is a bit of a mare to be honest.
I've got the exact same problem...the cleaning did not work....and there is no BnO service in the country where my equipment is....i'm at a complete loss...and about to give up ...
I may be a bit of a thicky but I would assume that it is less prone to dust issues when mounted vertically rather than horizontally. True or not??
hahhaaha Andy....it's a trying piece of equipment...same problem with the BC 9500...and we changed the C2103...and gave it a cleaning...to no avail....
Frank Rizzo:
I thought I had all the bad luck...
@ Puncher... not sure... would not surprise me as I went from vertical to horizontal!
Family site, Mobe!!!!
