Beosound 9000 - Newby Buyer Seeking Advice
seems that the only difference would be the chip for N-radio/N-music, correct?
The main user changes for the Mark 3 Type 257X are:-
- N.MUSIC is added for use with BeoLink PC 2 and Beoport
- You can now name CDs via Beo4
- You can now do Timer programming via Beo4
- Improved Random function (does not start with CD1 track 1)
- CD and CD track selection via the six buttons placed next to the CD compartment
- PIN CODE protection
- Mains switch has been removed from serial number 15397011
The main Technical changes were:-
- New design of the electronics and sledge to optimize the production process
- New microcomputer (μPH8)
- Changed sledge and CD single chip concept for VAM1250
- New DAC type on the Input/output select PCB
- New tuner module
- Improved optical positioning system for sledge (dust resistant)
- Plasma safe IR receiver
Interesting about the plasma safe IR receiver on the MkIII. I know my Mk I will not respond to the remote control if my plasma is on unless the image on the TV is very, very dark. Was the same with my AV7000 when I had it, when I went to a plasma from a tube set it had to go.
Where is the sticker with the Type Number and year of manufacture located?
The sticker is underneath the control panel as shown below
Thank you so much Keith! :)
Super, thanks Leo!
