Beosound 9000 Mk3 + BLC ML/NL = multiroom
Millemissen wrote:
Carolpa wrote:
ASlave is/was intended for connecting one audio ML device without speakers connected to the ML audio device.
On a side note!
That is the ‘kind of device’ that people nowadays could use, when they want to integrate e.g. a BS9000 with their NL/Mozart devices.
A new box with just that option would be great…….and would make sense to ‘relaunch’.
If they would make it wireless, it would be even greater.
All other functions of the NL/ML Converter are (for the majority) obsolete.
Exactly, 100% agree.
In line what I proposed in another post.
Thanks for the info on converter. I have just bought a BLC arriving in a few days.
I will connect a Beocenter 9500 to it, with a Beogram 9500 connected to phono input on the Beocenter, put the BLC in ASlave mode, and map Radio = Radio, Tape = A-Mem, CD = CD and Phono = N-Radio.
There will be no speakers connected to the Beocenter, all sound will be through multiroom devices as “Join”. Plan is to have Beoplay A6, Core and BL28 in the setup.
Will there be a conflict between the Phono (N-Radio) command and e.g. TuneIn on a multi-room device?
What is the correct A-option for the Beocenter when connected to the BLC?
no conflict with the app.
A option: I did place mine in option 0. but in principal other option will work. note: if in other option than 0 the Beocenter will receive remote commands and will behave accordingly with possible conflicts.
What if the BLC is away from the router......?
Any solution for this?
Or has the BLC always to be wired to the router?
Yes, it needs a cabled connection (which in any case always is better).
You might be able to use a PowerLine solution to get a wired connection or a wifi repeater with a network connection port.
Alternatively - maybe you could have a Masterlink cable from the installation to a location near the router?
