Jonfn wrote:
Thanks a lot Carolpa. It works!!
I think I missed the radio and aux before, thinking that CD and N.Music was the only needed ones
I don't think you'll have a purpose for the N.Music command in your setup.
AnalogPlanet wrote:
Thanks Carolpa, I can confirm that option #1 works with the A9Mk2 too , but not with the Stage. So I think option #2 is actually a safer bet across the current product portfolio (as much as option #1 is WAAAAY cooler!)
Btw, I had my BLC in VMaster mode, didn't know it can be in ASlave too... so I am testing it now and apparently all works well. 👍
ASlave is/was intended for connecting one audio ML device without speakers connected to the ML audio device.
option 1 should work with the first generation NL devices (Core, Essence mkii, BS35, A6, BV11, .....and A9mk2). I expected also the BS2 but I wasn't sure.
