Hi guys, finally managed to get both Beosound 9000 Mk3 and the BLC ML/NL in order to add BS 9000 as a CD source to my multiroom setup. Connection-wise, it's gonna be extremely simple: BS9000 connected just with MasterLink cable to the BLC ML/NL, and then BLC ML/NL connected with LAN UTP cable to my router.
After reading BLC ML/NL manual numerous times, and endless research here on the forum, I still couldn't find how should I set up the BLC ML/NL in order to be able to select the BS9000 in the B&O app and play CDs on multiroom speaker(s).
I acknowledge it should be fairly simple, but as I joined the B&O world only in "NL times", I have troubles understanding the "ML logic" in terms of sources, master/slave choice etc. If it is not too difficult to share a hint about how the setup of BLC ML/NL should look like I would be so very grateful. π
