After having owned my BeoSound 9000 Mk III for two or so years, I was dismayed when it started to randomly "act up". Some mornings, I would attempt to use the CD Play mode and the CD mechanism would fail to operate correctly - spinning briefly and proceeding to the "PAUSE" mode.
After reading as much as I could here on BeoWorld, I concluded that my symptoms were indicating the need to replace the laser which on the Mk III is the VAM1250 Philips.
What was interesting at the time (and to be honest, something that I did not grasp until after the laser replacement) was that the unit would typically act up in the mornings and if I could succeed in making it play a CD, the issue would go away. Of course, my reasoning told me that the unit was warming up, heat was being generated and, yes, the laser was bad but the laser was bad because it had a heat related issue. Probably an unseen sensitivity in the laser diode internals?
I eventually attempted to install an eBay sourced VAM1250 laser-only (with the completely different circular laser diode solder crown under a metal cover) and it did not work! Lesson learned.
I then moved forward with the purchase of the original B&O issued VAM1250 Laser Kit that I was able to purchase here in Massachusetts from Atlantic Systems for about $180.00. I installed it, ran the test mode sequences and my unit now operated as new.
Unfortunately, after all of this was done and the money spent, I began to think more about the symptoms of my BeoSound 9000 Mk III laser failure and its relationship to temperature. I then realized that the unit, when acting up, was always failing on the cold winter mornings. Here in New England, the winters are cold and snowy and we routinely turn the thermostat down to 58 degrees (F) at night and just before turning in. I always turned on my music first thing after getting out of bed and before the house had a chance to warm up. This recollection confirmed that it was a morning issue, a winter issue and therefore a thermal issue. Ok, I kind of actually already knew this but I was onto something that I just wanted to solve.
So..... I pulled out from my parts box the original B&O/Philips VAM1250 laser with the linear (black plastic) laser diode crown and inspected the 12 solder points - six on each side - and guess what I saw under my 30X loop? Yup, all 6 of the solder points on one side of the laser were cracked. Problem solved and, unfortunately, a bit too late.
I have included some photos of the cracked joints for all to see and hopefully, someone can benefit from my findings.
If you are having a failed laser issue with a BeoSound 9000 Mk III, do a minor disassembly to the point where you can get a clear view and access to the crown of the laser unit. Confirm with a loop the presence of solder joint cracks at the crown, dab some flux with a toothpick at each solder point and re flow those joints. You may just save yourself some major surgery and lots of money. Or if you are not up to working on your own gear, share this post with your repair shop. Good luck!
And by-the-way, the original Philips VAM1250 Laser units (with the linear laser diode crown) are no longer available anywhere! (I know - I've searched everywhere!) Except..... those that were purchased by Bang & Olufsen just prior to the cessation of manufacture by Philips. So essentially, after the B&O service inventory is exhausted, those of us who own BeoSound 9000 Mk III's might be in a real pickle.
Now, If you own a BS 9000 Mk II version (which I also owned and serviced) you're in luck as that unit uses the Philips CDM12.4 and that laser unit is also available on eBay and they work. I did one and the change out worked beautifully! I purchased my CDM12.4 from the eBay USA seller who sells under a juke box supply house service called foolnme.
[As a side note and as stated earlier, during my repair process, I noticed a big difference between the original B&O/Philips VAM1250 Laser Unit and the eBay sourced VAM1250 in that the Laser Diode solder crown on the B&O/Philips was a linear solder crown of 12 solder points total with 6 points on each side of a central black plastic rail of sorts. The eBay sourced (and obviously not authentic Philips) has a metal shield over the laser diode solder points and the points are in a circular assembly. I researched on line and found the data sheet for the Philips Laser Diode (see photo of data sheet) and it is shown as a linear unit and is number GH6C005B3B. Why is this important? Because one can conclude that the reproduction VAM1250's are absent the critical and technically necessary Philips Laser Diode and are obviously equipped with an imitator that just isn't working with the BeoSound 9000 Mk III.]
Michael
