I wondered if anyone out there can help me with an unusual fault on a BEOSOUND 9000 [MK-3] to save it from the skip?
When powered up the Standby light comes on, lid button opens & closes the lid as usual however, the unit will not come out of standby. Every 4 minutes or so the unit seems to re-set, ie, the Standby light goes out & CD mech. makes motor noises, then Standby light comes back on again!
If I use the BEO4 remote control, the unit can be put into ‘Option #1’ & then put into service mode – again after about 4 minutes the unit re-sets & leaves the service mode & also reverts back to ‘Option #0’.
I have that 4 minutes to run each test mode (which is a pain) – upon running the test modes everything seems to be okay & all tests pass with the exception of the following:-
TM27 ~ 1-IOP-19 (TP MODULE HW ERROR APOS),
TM31 ~ TM ERROR.
I have checked much of the circuitry & everything looks good so I am thinking it is a fault with the *** or ***.
B&O are being arsey and seem to refuse to supply parts & just want me to send the unit in to them, which I don’t want to do as the charges will be more than the unit is worth. After all, who uses CD’s any more? It just remains a fancy looking radio & pre-amp to plug a music playing device into….
Any ideas on the fault & where I can obtain ****** would be appreciated.
Cheers,
Mark
EDIT by Beoworld moderator.
We kindly ask members to upgrade to at least silver membership level to place sales/wanted ads.
