Extract of the service manual you should try to get.
Test mode activating (by Beo4)
Wait 20 - 30 sec. after connecting to mains.
Since BeoSound 9000 is in option 0 if Power Link speakers are not connected, the option has to be changed to 1.
Option 1 can be obtained by short-circuiting pins 2 and 4 on the Power Link sockets. See Brief operation guide for further information, if necessary.
By means of remote control from St.by (can only be done if the product is not in option 0) :
Press SHIFT 9 0 2 5 8 with no more than 2 sec. between the individual entering. The remote control has to be in RADIO or CD option.
In test modes the tuner is fully functional and may overwrite the display but the TM will continue.
Select CD to view CD test modes.
Deactivating test mode (by Beo4)
Press • and the display shows “TESTMODE OFF” or disconnect from mains.
TM71
Mechanical test of finger protection, sledge and led.
CDs must be loaded in positions 6, 5, 4, 3, 2 but no CD in position 1, (the position nearest the LOAD button).
The CD must be stopped and the lid must be shut when the test is activated.
The following sequence is executed:
- End stop is found, the sledge runs slowly. This tests sledge tacho, sledge motor, calibration of the end stop switch.
- Lid opens and closes. This tests optocoupler for glass lid.
- Test of finger protection circuit.
- The sledge runs the longest possible distance slowly once, then quickly twice. This tests the sledge tacho for phase errors between quad 1 and quad 2 (the finger protection circuit is cut out during the test). When the sledge is running it must run “properly”.
- The lid opens.
- Autocalibration of CD positions. This tests calibration, disc detector, sledge motor, sledge tacho, clamper motor, clamper optocoupler, and jaws. The clamper is noise-optimized during the autocalibration.
- The sledge runs to the original position, i.e. the sledge position prior to activation of sledge test.
When error in CD test mode the Error-number refers to TM27 CD-errors.
TM73
Adjustment of autopositioning.
Test mode 71 must have been executed.
- Press SHIFT 9 0 2 5 8
- Open the lid and load a CD.
- The sledge must be placed in the position where the CD is loaded.
- Press 7 3
- If the test is OK the display will show: APS ADJUSTED.
- If an error has occurred during the test, the applicable error code can be seen during a test mode 27.
