With all the hype around the 9000c, it seems our old units are back in the light again; thank you Recreated Department!
Well, mine is a MK2 and has IR troubles. I believe it's "again" a matter of three capacitors.
But looking at the three service manuals, MK1, MK2 and MK3 and also to some pictures on the web, I'm unbale to see if the PCB14 is all SMD or may have those capacitors easy to replace.
This unit is quite long to dismantle and that one has been a lot of time, I dont want to do it for nothing with the risk of breaking something just to discover the capacitors are beyond my skills to replace.
Anyone knows to what looks like the IR PCB in MK2 Beosound 9000?
Thanks.
