Hi all,
my shiny new white BS9000 has an interesting characteristic....it clicks periodically 🤔
It does it when playing CDs but also when in standby!
anyone seen/heard this before? ❓
regards
Ray
Hi all,
regards
Ray
Hi Ray
Ever heard of "white noise"?😁
Ray,
Tried to look it up through B&O, but couldn't find any similar reports. I would ask the dealer to check it out!
Roger
Is it a mechanical click?
It could be the orientation settings!
Hi - yes mine has clicked for the last twelve years. I guess i hear it a couple times a week, but it might be happening more often.
Strangely - i am not sure i have heard it click since cd mechanism was replaced approx 2 months ago....
However its never worried me,
Cheer
Russ
Yes mine clicks too, I usually notice it more first thing in the morning when all is quiet and its in standby. I first heard it click a couple of years ago, some mornings it clicks more than others.
It took me ages to work out that it wasn't the central heating pipes expanding!
It seems to function perfectly though, but I sometimes wonder what its up too.....
Paul
Thanks for the replies guys,
hmmm...can't make out if its mechanical or heat expansion 😮
as much i love B&O stuff with all their indiosychrisies quirks, not sure if i am happy with it on a £3000 cd player 🤔
