BeoSound 9000 . CD is not working. Any hints?
Hello BeoWorlders,
yesterday the CD section of my beloved Beosound 9000 MK II quit working.
The clamper section moved to each disc, the light works, the clamper "grabs" the disc, but the the CD (the motor) doesn't rotate. I hear 3 or 4 very gentle clicks (ca. 1 per second), then the display shows "Pause".
I turned it off with the red button, cleaned the 2 sensors and blowed some air behind the clamper. But: same problem.
Has anybody of you guys an idea, what the problem is? Do I need a new CD drive? Do I have to bring my BS9000 to the B&O-doctor?
Thanks, JOV
you can try to clean the laserlens
Maybe the motor spinning the disc has failed?
Isn't the B&O CD mechanisms philips? So that shouldn't be a problem to fix.
