Thanks, that sounds really good, and as the Shape does work with my TV I do need to investigate again into the adapter,
BeoSound 9000 Aux Port
I just connected my B&O A8 Earphones to the AUX adapter, but no signal,
if I use the earphone outlet both sources are working, (Radio and/or CD),
so it looks like I got a bad adapter from my dealer, right?
Please use the headphone socket on the edge of the Beosound 9000 to connect your earphones, not the Aux socket, then they should work fine.
Kind regards, Steve.
Yes, it is quite common for DIN adaptors to be the 'wrong way around' - i.e inputs instead of outputs. If you explain the problem to your dealer, he should be able to swap for the correct lead.
so it looks like I got a bad adapter from my dealer, right?Yes, it is quite common for DIN adaptors to be the 'wrong way around' - i.e inputs instead of outputs. If you explain the problem to your dealer, he should be able to swap for the correct lead.
The dealer shouldn't be selling a DIN adaptor anyway - the headphones plug into the headphone socket, not any of the DIN sockets!
^ Steve and AdamS need to read Penfolds' 14 Dec post to make sure that they are answering the right question, which has nothing to do with headphones!!
Fair point Guy!
I was answering Penfold's latest enquiry, but yes, to answer the original question, this does sound as though he has an Aux input adapter, not an Aux output adapter.
Thank`s Adam, but I used the A8 headphones only to test, if there is any signal, because I will use that signal for my CORE as line-in. !?
(same as the TV)
Ahja,
sound`s like I`m on the right track, will let you know the outcome ASAP, but Covid is slowing down...
My dealer told me that I would need a unique = selfmade adapter as they are "usually only made" for AUX in,
and that no AUX out adapters available, can anybody please advice me what I should order?
