Hi I have found the exact same issue with my Beosound 9000, the digital out is fine, but along with the volume also if I change disc or track I get the same 'Buzz' also if it does a change the 'Buzz' is also present. It is not a cable fault in my opinion it is an issue with PCB 32
BeoSound 9000 Audible Volume Buzz
The only way I could eliminate the hum was to go AUX IN on the B and O head unit connected with the PC out jack.
Going PC direct to the B and O speakers is where the hum is. Its not the PC sound card, nor those excellent cables from Steve.
