Hi Dr. Alex,
Sorry to hear that you are having problems.
The issue with pulses of noise when you change volume on a B&O system is different from having a non-B&O device (eg. computer) that generates noise when it is powered down.
First, please can you unplug the computer cable from the Beolab 11 and check that the DIN plug has 7 pins? If not, then the cable isn't the correct one for Beolab 11.
If you have the 7 pin DIN cable in place, please can you check if the Beolab 11 hums when the computer is powered on? If the sub only hums when the computer is powered off then the cable is OK - the usual cause of this issue is the computer allowing noise to be picked up and passed to the speakers.
If the Beolab 11 doesn't hum in any situation, but the Beolab 6000s hum - please let me know and we can look into this further for you. Any questions, please ask.
Kind regards, Steve.
