I have all of my media-stuff controlled by Logitech Harmony (Elite, hub + blasters) and everything is working great. Beosound 9000 also works after quite some work with re-assigning a lot of buttons.
When adding a device as manufacturer "Bang & Olufsen" and device as "Beosound 9000" the device is added as "Bang & Olufsen Mini System". This in it self is not an big issue, naming and buttons can be re-arranged.
Now, the issue.
Using Beo4 number buttons in CD-mode pressing "4" starts to play CD 4, this works fine on Harmony. To change the track number with Beo4 we need to press "List" to change Beo4 to "Track"-mode and then use the number-buttons. This works fine with Beo4 but I cannot replicate this to Harmony. Any ideas?
I found out that when I press "List" on Beo4 it transmits an IR-signal, I then copied this to Harmony and tried using Harmony as "First press Track then press a number" but this does not work.
Yes, Beo4 is beautiful, so is some of the 6-7 other remotes I have stuffed away, whole apartments, including lights, can be controlled with Harmony and really would like to get my "new" 9000 to do that too.
Any advice or experiences?
